1990 Ranger XLT 4X4 Not Working
Greenwoodguy456
Missouri
Ford Ranger XLT
The ranger had the electric switch, once I press the button the 4X4 light comes on and I hear the Module click behind me. It will not kick into 4 wheel drive and the passenger side hub ticks. Mind you it will go in the low range gears but not 4 wheel drive. Does anyone know what it is??
Thanks,
Brent
Uncle Gump
Token Old Guy
13,452
Ottawa IL
Ranger/BroncoII
4.0L SOHC/2.9L
Sounds like a bad hub...
8,369
Yes, +1 ^^^
Welcome to TRS :)
Ranger 4x4s have an OPEN front differential, so if one of the hubs doesn't lock then no 4WD, the ticking noise when moving means one hub is not fully engaged
I assume you have "automatic hubs", which can break, manual hubs are better
You can pull the wheel off and the hub cover make sure its not packed with grease, if so clean off as much as you can and used some motor oil for lube, axle grease is too thick and makes hubs stick
