ylidk
- Jul 16, 2018
- 7
- KS
- Ford
- Engine Size
- 2.3l L4
Hey there everyone, I have a 1991 Ranger with the 2.3 L4, RWD, M5R1 transmission. The truck was cheap and didn't run when I bought it, but once I got it running it ran pretty well all things considered.
Recently swapped the head from the 1991 2.3 head, to a spare 2000 2.5 head I had in my garage. The original had compression leaks via the exhaust valve on cylinder 2, and possibly other valves due to lifters that I was able to press down by hand, so I decided to swap the entire head with one that I verified to be good, albeit from a later engine with slightly different flow characteristics.
Swap went fine, timing belt lined up fine and the cams were aligned in the same way when I replaced it, yet it ran rough for reasons I could not figure out. When digging around, the red/green wire that leads to the ignition control module / crank pos sensor / noise filters that is hot in run / hot in start grounded against the engine for a brief period of time and fried something. All the fuses checked out, and the relays too, so I began to follow this test procedure:
https://easyautodiagnostics.com/ford/2.3L/icm-and-crank-sensor-tests-1
When following these tests the #1 wire, the red/green wire from before, failed test number one. Not only was the wire not reading 12V between the negative battery post, it read continuity with it, and when I turned the key to "on" it read around 2V. Metering this wire against the positive, with the key off, there was 12V potential, and with the key on it read 10V.
Clearly grounding this wire out caused something weird to happen, whether it melted to a ground wire somewhere that I have yet to find as I have been tearing apart this wiring harness to track down or something else. Disconnecting the engine wiring harness from every plug except for the one this at contains the red/green wire to the main wiring harness. the wire still reads that it is grounded, so it is not the ICM or CKP. If anyone has any ideas or suggestions I appreciate all the help I can get, this issue is killing me.
Thanks in advance!
Thanks in advance!
