nameiztaken
- May 11, 2019
- 0
- California
- Ford Ranger 2.3
Update regarding a previous post:
Bought a 2.3l ranger for dirt cheap and found 30psi compression on Cylinder 1, 2 and 3. Cylinder 4 has 170psi dry.
Compression rises 10 psi on all cylinders when oil is added (wet test).
Seller states he was driving it up a hill on a "hot day" and the engine began making a "noise" and died. He mentioned something about replacing the timing belt, but I'm unsure if he replaced it.
I can't run the engine without buying a harmonic balancer and crankshaft hub, which I don't want to buy until the compression is fixed.
Any ideas are appreciated.
