1992 ranger 4x4 4.0 supercab 5 speed swap
Trickflow43
Findlay Ohio
Solid Axle Swap 4x4
2in suspension
I've been researching this swap as my a4ld lost park and 2nd gear. I see I need a M5OD-R1 trans the clutch/brake pedal from a 90-92 the master, lines, slave, flywheel, and clutch. Wiring isn't a big deal as I can figure that out for my lights. My area of question is I know my 1350e case will bolt up but can I reuse my drive shafts, do I need a manual ecm because I see that posted both ways? Also let me know if I missed anything. Thanks!!
alwaysFlOoReD
5,086
Calgary, Canada
'91, '80, '06
Ford, GMC,Dodge
4.0,4.0,5.7
The clutch/brake pedal bracket.
The pcm will work but I think it idles high and gives a cell because it looks for solenoid that aren't there.
Trickflow43
Findlay Ohio
Solid Axle Swap 4x4
2in suspension
Do you know if my stock automatic driveshaft can be reused?
alwaysFlOoReD
5,086
Calgary, Canada
'91, '80, '06
Ford, GMC,Dodge
4.0,4.0,5.7
I don't know. I think there is something in the tech section that compares trans length.
snoranger
Professional money waster
ASE Certified Tech
13,653
Jackson, NJ
'79,'94,'02,'23
All Fords
2.3 EcoBoost
