RonSerling
- Mar 25, 2013
- 13
- Ford
- Engine Type
- 4.0 V6
- Engine Size
- 4.0
- 2WD / 4WD
- 4WD
- Total Lift
- ummmmm 4" could be 6 but its a TTB and the little bugger varies from time to time !! LOL
- Tire Size
- 33/12.5 15
Good Morning,
I have a 1993 Ranger with a 4.0 in it that I am having an issue with. First thing so you know this is a brand new long block with all the other items needed taken from the old engine. When I start it up and it is cold it runs great as it idles at about 800 rpm and has all the power you could ask for. After about ten maybe fifteen minutes it still runs great with all the power but I cannot seem to get it to idle properly. If I am driving normally and say come to a traffic light it will idle around 1600 rpm and if I hit the throttle it will come down a bit maybe to 1100. I looked thru a bunch of different Q&A's to see if they could be of help and I have done a number of things they all talked about. I put a new IAC on, I replaced the TPS and also replaced the ECM water temperature sensor but nothing seems to have eliminated the issue. I also took the MAF off and took the sensor off the housing and gave the housing a good thorough cleaning also. I have checked everything and anything for vacuum leaks and cannot find any there. After all this when I started it up it idled really high and when I unplugged the IAC it came down to normal. So I built a block plate and installed it in between the IAC and the manifold and like I said now when it is cold it idles perfectly but after it warms up it is all over the place. 16 - 1800 at times and then 900 and surging at times. Im pretty good with most mechanical things but this one has me stumped so I am asking for any suggestions or help anyone can provide !!! I hope someone may be able to give me something to work with as I need to get her smogged here soon and I am sure it will not pass with this idle issue. Any suggestions or ideas would be greatly appreciated
Thanks in advance
Thanks in advance
