ericbphoto
Overlander in development
- Feb 7, 2016
- 16,593
- Age
- 59
- Wellford, SC
- Ford Ranger
- Engine Type
- 3.0 V6
- Engine Size
- 3.0L
- 2WD / 4WD
- 4WD
- Total Lift
- 6"
- Tire Size
- 35"
- My credo
Re-installed, and bled the brakes today. Installed sway bar with all new bushings. Re-installed the front drive shaft.
I started installing the steering. But I can't find the instructions for the superlift forerunner steering kit. I'm not sure where the bracket is supposed to mount on the passenger side. I also noticed that the tie rods are different lengths. Will need to figure out which one goes to which side. It might be obvious once I get the link for. The pitman arm installed.
Also noticed torn boot on front drive shaft when I was bolting the shaft in. That should be an easy fix once I get a new one.
Sent from my SM-G920V using Tapatalk
