1999 Gauge cluster
CorbinFawver
New member
Shelton, Washington
3.0L "Vulcan" v6
My 1999 3.0 xlt has my fuel gauge and temperature gauge in the same panel. Neither work and neither do the lights in that section(left hand side) can I just replace that one section or do I have to replace the whole cluster? Will that section of cluster work from an explorer?
Rock Auto 5% Discount Code: 173A8B749AB83C Expires: January 1, 2020
Well-known member
521
On the Diagram below it looks like Connector C215 on the back of the cluster might have some loose connections
Used by Fuel and temp gauges also 1/2 the bulbs(3)
EDIT: 10-31-2017
There seems to be an error in the diagram
MIL(CEL, check engine light) wire shows it uses C216-9 but Pink wire from pin 2 on PCM is connected to C215-9 in diagram
Pin 2 on PCM is correct, but not sure on the C216 or C215 connection
1998 diagram shows C216-9 as correct
