2.0 swap to 2.3 question
Otto57
7
Michigan
I want to replace my wore out 2.0 with a 2.3 and I found a 2.3 from a 1977 pinto. I understand that the blocks should be the same with the exception of the bore but my question is will my brand new 2.0 clutch fit the 2.3
Daniel Black
44
Leicester, NC
302
205/60R15 & 225/60R15
It should. I used the new clutch, pressure plate and even the flywheel from my 2.0 when I swapped in a 2.3.
Otto57
7
Michigan
Ok that sounds great. I've got enough work ahead of me without dealing with clutch issues. Thanks for the input, I need all the help I can get
Daniel Black
44
Leicester, NC
302
Let me know if you run into any problems. My 1987 was a 2.0 and now sports an '85 2.3 from a Mustang. I don't remember anything that didn't interchange other than different intakes.
Otto57
7
Michigan
Ok thanks again. Hopefully all will go well
