2.3 carb help. What are these gizmos?
Dirtman
13,326
41N 75W
It's up there.
It's down there.
Round.
I poop in the furnace.
Yea it's an eslinger or something cam gear. I just left it at zero and didn't mess with that.
19Walt93
4,453
Canaan,NH
351
3"
235/55R16
There's to be an inner timing cover bolted to the engine behind the belt with the cam timing pointer on it. The cam pointer would be just about straight down from the cam bolt. If you run that without an inner cover you could start it one morning and throw the belt when it grinds up the mouse who slept there last night.
Dirtman
13,326
41N 75W
It's up there.
It's down there.
Round.
Yea that cover is no where to be found. :rolleyes:
19Walt93
4,453
Canaan,NH
351
3"
235/55R16
Set it with the mark on the cam straight down and you'll at least have a starting point. It'll probably run and when you drive it you'll know right off if it's wrong, even 1 tooth off is noticeable.
