2.5 Stalls after warming up
Jim2
Honolulu HI
2.9 L
Hi all, I haven't been around for a while but it looks like I'm gonna get another Ranger...
I'm told it runs strong, but it tries to stall at at red-lights after warming up. (Manual trans).
The IAC is suspected, but I'm wondering if there are any vacuum lines that are hard to find on this engine.
I ask about the hidden vacuum lines because I had problems with the idle on my F-150 years ago. I replaced the IAC, but that didn't fix it... After a while, someone told me about a hidden vacuum line that cannot be seen. You just have to know where it is, reach in, and find it by feel.. Once I found it, it was a simple fix.
Thanks in advance! Cheers,
Jim
Jim2
Honolulu HI
2.9 L
Well, I bought it...
Just as described, she stalls once warm. Always fires right back up though, so that's good.
I found a broken vacuum line, and there's a youtube vid about it already. It operates the vent for "Max AC"... Apparently that line is known to break, I saw other stories about it too.
I also found that the MAF base has a chunk missing at the seal. In the pic below, it was covered with aluminum tape. But I don't think that's what causes the stalling. That tape looked airtight, and I drove it with the hole exposed, and there was no difference.
In the background (top right), you can see the broken vacuum line. It's a hard grey line.
Jim2
Honolulu HI
2.9 L
I stopped by the store and got the codes read today, and it was only P0102... (MAF low voltage)
The tape was removed at that point, and she still ran the same...
One other thing, the check engine light doesn't work... It doesn't come on at start-up.
Jim2
Honolulu HI
2.9 L
In this pic, there's that broken vacuum line..
On the coolant hose that goes to the heater core, the "T" is leaking...
It's pissin on the wires below, but I don't know what that part is... it's mounted to the exhaust manifold, and it's loose.... it rattles around...
Anyone know of a good "parts fische"?
Jim2
Honolulu HI
2.9 L
fwiw... a remanufactured MAF sensor fixed it right up. She purrs now. No more stalling.
alwaysFlOoReD
5,086
Calgary, Canada
'91, '80, '06
Ford, GMC,Dodge
4.0,4.0,5.7
Thanks for posting your fix.
