2.8l builds?
KRCT-2585
Northern Utah
Hey guys I'm looking at maybe buying an 85 ranger with the 2.8. Does anyone here have one built? If so, what's the best route to go and how does it perform?
8,370
Welcome to TRS :)
2.8l info here: https://therangerstation.com/tech_library/2_8L_Performance.shtml
Pretty old technology, designed in early 1970's, rated at 115HP
But still a serviceable engine that can take alot of miles
They did have head hot spots so watch temp gauge, modification can be done when heads are off, how to in above link
The 2.8l block has the same bolt pattern as the 4.0l OHV used in 1990-2000 Rangers so it was a popular swap to get more power, 160HP with fuel injected distributorless engine
KRCT-2585
Northern Utah
So I could get the older 4.0 and drop it in without changing the trans or motor mounts? Sounds like a fun route
8,370
Yes, go here, bookmark this page: https://therangerstation.com/tech_library/index.shtml
Click on Engine & fuel tech section
There are quite a few links for 4.0l swaps
The 2.8l and 2.9l use same block, as did the 4.0l OHV, they are all Ford Cologne V6 engines
Difference for 2.8l is that its a carburetor engine and the 2.9l and 4.0l are EFI so you do need to add a high pressure fuel pump and a Return fuel line, which the 2.9l would already have
1990-1994 4.0l OHV with computer and wiring will be easier swap than the 1995-2000 because of the older computer, EEC-IV 60 wire, in 1995 Rangers got the EEC-V 104 wire computers, still used today by Ford
