Welcome Visitor! Please take a few seconds and Register for our forum. Even if you don't want to post, you can still 'Like' and react to posts.
is this an upgrade or cheap swap. the stronger easy swap is the M5OD.So the fm146 will fit either 2.8 or 2.9, but I need to get the 2.9 flywheel? Or can I use the 2.8 flywheel? Which flywheel woould be better on my 2.9?
Upgrade swap from an a4ld 4x4 with electric xfer case. I have a EDIT: fm145 with manual xfer case in unknown condition and a 2.8 flywheel and clutch assy that came off a 2.8 4x4.is this an upgrade or cheap swap. the stronger easy swap is the M5OD.
Bob
yesSo it would be that much better to do the M5R1? What all would I need as far as flywheel, clutch , drivelines, etc to do the M5R1?
