2.9 intermittent spark from coil!!?
Chuckc
Florida
Bronco ii
1988 bronco ii curse.. replaced fuel system. Most sensors and whole ignition system including computer.. went threw wiring harness fixed sketchy connections. Runs rough backfiring. Has intermittent spark from coil can watch timing light or in line spark tester blink steady and stop at same time engine misses (intermittent coil signal) please help!!
rusty ol ranger
2.9 Mafia-Don
7,483
Michigan
177 CID
Sounds like the ignition module or pickup coil.
Pull codes and lets see what ya get there.
Chuckc
Florida
Bronco ii
New ignition coil and new distributor
8,370
Wouldn't matter what is "new"
New now means "never tested so YOU TEST IT and we will replace it under warranty"
So because its "new" just means if there is a problem get another one
The TFI spark system is self contained, unhook the SPOUT wire jumper so there is no connection to computer
Test spark again with timing light
If its still misfiring then its down to TFI module and distributor, for sure
If TFI is not grounding the Coil, then ungrounding it to spark in a regular rhythm, its usually the distributor Hall Effect sensor or the rotor/cap setup
Distributor is new so bushings should be OK, but not always, you can get a wobble so the coil spark can't jump the gap at rotor/cap so you get that missing spark/timing pulse
The hall effect sensors is pretty simple and not likely to cause an issue, but its "new" so suspect
Locotomb
62
Puyallup, WA
2.3l
6inch custom fab lift/86
Bagged 3 inch custom drop beams 88/89 Custom triangulated and step notched rear
35/12.5/r18
Everything looks better lower
New cap and rotor? Resistance test plug wires?
Locotomb
62
Puyallup, WA
2.3l
35/12.5/r18
Oh yeah and keep your coil/distrib wire away from all other wires as much as possible.
PetroleumJunkie412
Official TRS EV Taunter
6,565
Dirtman's Basement
2.9l Trinity
From personal experience, unless your TFI module and hall effect sensor both say "Motorcraft," neither will work.
Chuckc
Florida
Bronco ii
Thanks guys nice to have some reassurance before ordering and replacing new parts.. I have new tfi module and Hall effect sensor on the way.. their not motor craft might debating sending back and getting better quality parts
Chuckc
Florida
Bronco ii
Also in cleaning up some of my wiring connections I cut out idm resistor.. is this necessary?
Chuckc
Florida
Bronco ii
Only code 67 and I’ve replaced nutral safety switch code still their
rusty ol ranger
2.9 Mafia-Don
7,483
Michigan
177 CID
Code 67 comes up when you do a KOEO test with the transmission in gear (manual). Disregard it.
Chuckc
Florida
Bronco ii
Well replaced tfi and Hall effect sensor and same thing actually running a bit worse now..
PetroleumJunkie412
6,565
Dirtman's Basement
2.9l Trinity
How does it run with the spout connector disconnected?
What is.your base timing set to?
