2001 running rich, no power, poor MPG’s
Kesh2011
Colorado
2001 running rich, no power, poor MPG’s,rough idle
New member here. I have a 2001 3.0 automatic 4x4 with 180k on the odometer. I’ve had the truck for several years and it never has really run right. I have treated the engine with seafoam, Clean the mass airflow sensor, and I went to change the plugs expecting them to be fouled but found them to be in pretty good shape. They were a nice tan color. They did not look like fouled plugs indicating a rich running motor. Instead of changing them I cleaned and gapped them because I may treat the motor with seafoam again. As the title says the truck has no power and only gets nine or 10 miles per gallon. I expected the plugs to be fouled but was surprised to see that they were not. I also replaced the coil pack about a year ago because I had a misfire codes on the scanner at NAPA. So my question is if the truck is running rich and is getting bad gas mileage why wouldnt the plugs be fouled? The truck does run a little better after the work I have done to it. I filled it up again and will be checking in. Any help would be appreciated.
gungfudan
19
Mississippi
Mazda
N/A
N/A
What grade Gas are you running?
Kesh2011
Colorado
alwaysFlOoReD
5,080
Calgary, Canada
'91, '80, '06
Ford, GMC,Dodge
4.0,4.0,5.7
Any codes? In memory?
Kesh2011
Colorado
P0300, p1684
alwaysFlOoReD
5,080
Calgary, Canada
'91, '80, '06
Ford, GMC,Dodge
4.0,4.0,5.7
P0300 Random/Multiple Cylinder Misfire Detected
P1684 Metering Oil Pump Position Sensor Circuit
P0300 seems to be the culprit for the rich running. It makes sense for clean plugs because there isn't just one cylinder running rich, so the plugs stay clean. I don't know the ignition system on your truck but I would start with that. Unfortunately I can't help more than that.
Indiana
If there is an ignition module, try that. My impala misfired on every cylinder and had zero power, thing barely ran. New module and it runs like a top. Not EXACTLY sure of the setup on that truck but maybe similar?
Kesh2011
Colorado
I did changed the ignition coil pack a year ago with no change in performance.
Uncle Gump
Token Old Guy
13,423
Ottawa IL
Ranger/BroncoII
4.0L SOHC/2.9L
If you seafoamed the engine... it probably cleaned the plugs a certain amount. That would alter the plug read to an extent.
What kind of plugs are they? Anything other then Motorcraft or Autolite in my experience just don't perform as well.
Kesh2011
Colorado
motorcraft platinum agsf32fm
Uncle Gump
Token Old Guy
13,423
Ottawa IL
Ranger/BroncoII
4.0L SOHC/2.9L
Ok...
I think I would put a vacuum gauge on it and do a little checking to see if there is an exhaust restriction. With the misfire code you're dumping a bunch of unburned fuel into the converter. Google restricted exhaust testing for the how to. It may not be the problem... but you can eliminate that possibility easily.
Kesh2011
Colorado
I thought seafoaming the engine would foul the plugs. Truck has 180,000 miles and is almost 20 years old. I may seafoam the engine again since it probably has never been done.
8thTon
--- Banned ---
806
Pennsylvania
Mechanic in a bottle isn't likely to accomplish anything but pissing off the cats.
gungfudan
19
Mississippi
Mazda
N/A
N/A
Do you think it could be a bad injector or pcm issue telling the injector to stay open longer? I am probably way off the mark just a thought.
Kesh2011
Colorado
I don’t know about the injectors. I did put a mechanics stethoscope on them and they all sound the same. After doing the above service that I described I disconnected the battery to reset the computer. I will wait for the check engine light to come on again and check codes again. It does feel like there is more power and it runs a little better but I don’t think it’s 100%.
