2008 ford ranger camber kits
smitty2855
ny
3inch body lift
Hello, I have a 2008 ford ranger 2 wheel driver XLT with front coil springs and am doing new ball joints and upper control arms so I am told I need new camber bolt kits as the factory ones don't adjust for proper alignment, tires are wearing on inside edge and have replaced shocks too. what are the best ones to buy and which ones have the most adjustment I was thinking moog. just don't wanna buy some crap that wont adjust or torq properly. thanks in advance.
pjtoledo
2,965
Toledo Ohio
Fords
3.0 2.3
there are several camber kits, they all look similar to this.
you may already have one, or you may have individual squares that aren't adjustable.
they are just a bolt and offset cam plate, I put the NAPA parts on my 2005 coil spring truck years ago.
the range of adjustment is limited by the slot in the frame brackets.
smitty2855
ny
3inch body lift
also should I get the front camber kit with bolts that are greasable?
8thTon
--- Banned ---
806
Pennsylvania
Wear on the inner edges can simply be excessive toe out.
smitty2855
ny
3inch body lift
thanks all for info going to get Moog part #K100348 as per moog service told me this is the correct part. Ordering from carid.com greaseable 27 dollars per side 2 kits. just a side note truck is 2008 ford ranger so there has been enough time that it really needs a proper alignment and replacing ball joints and upper control arms and shocks so will need cam bolts to do alignment anyways. factory cam bolts are not ajustable
smitty2855
ny
3inch body lift
Hello got the kits from moog thanks.
