2wd 3.0 with 33s
mazdakiller
winston salem ,NC
mazda
So I put 33s on my truck and I can tell I need to re-gear the rear end. My question is, what gear ratio to go with and how do I tell if its a 7.5 or a 8.8. I do know it has 4.10 gears in it right now. Another thing is I want to get a locker but I'm not sure on what to get there either. Any help is appreciated
ericbphoto
Overlander in development
16,592
Wellford, SC
6"
I would recommend 4.56 gears. There should be a tag somewhere on the axle that tells what axle it is, the gear ratio and whether it's limited slip or not. Check out the axles and gears tech articles. There's info there on how to read axle tags, door stickers ( that tells you the axle, too) and what axles came in which trucks. I have an Aussie locker in my 8.8" with 4.56 gears, running 35" tires. If you have an FX4 level2 8.8" with 31splines, you could get a Thorsen limited slip unit for an awesome price right now. There was a thread posted earlier today about that.
Ranger850
Doesn't get Sarcasm . . .
4,691
Tallahassee Florida
Stock 2"
Stock
Can you get FX4 on a 2wd
ericbphoto
16,592
Wellford, SC
6"
Sorry. I forgot the 2wd part. Of course you could swap one in.
mazdakiller
winston salem ,NC
mazda
@ericbphoto i was thinking 4.56, so ill go with that, I don't have any stickers on the door so I wasn't sure if the tag on the axle would say. Which would be better, limited slip or a locker, I'm not to familiar with axles.
4x4junkie
583
So. Calif (SFV)
2.9L V6
35x12.50R15
The 3.0L is a high-revver, go with 4.88 gears (hopefully you have the 8.8", which some 3.0L trucks after '97 did have, as 4.88 isn't available for the 7.5").
ericbphoto
16,592
Wellford, SC
6"
In my opinion, a good limited slip setup is better if you're going to drive it on the road a lot. But they're more expensive. The Aussie locker or lock-rite or similar "lunchbox locker" is a decent compromise. Around tight corners, it will release if you don't apply torque. Ie; get off the accelerator. It makes a bit of a clicking noise when it does that. But all is normal.
Dirtman
13,326
41N 75W
It's up there.
It's down there.
Round.
I poop in the furnace.
I say 4.88 if you're doing more offroad and or city/around town driving. If you're hitting the highway alot then 4.56. But as stated the 3.0 makes power at higher rpm so even on the highway 4.88's shouldn't be an issue.
ericbphoto
16,592
Wellford, SC
6"
I agree. My truck performs about the way it did stock. But I have a manual transmission. If I had an automatic, the 4.88 might make the 3.0 a little bit happier. If I had 33's it might be a toss-up for me.
mazdakiller
winston salem ,NC
mazda
iight,it is a 5 speed so I'll go with 4.88.
mazdakiller
winston salem ,NC
mazda
ok so now that im ready to do this, im being asked what spline the truck is 28 or 31. Im assuming the spline on the pinion is what they are asking for but how am i able to tell without taking the truck apart?
Dirtman
13,326
41N 75W
It's up there.
It's down there.
Round.
They are referring to the axle splines. Your's is 28 spline. Only fx4 lvl 2's had the 31 spline axle 8.8"
Junk Collector
Truck of Month
4,793
Rapid City SD
I would also concur with the 4.88 recommendation. 4.56 would probably work but your clutch will enjoy 4.88 a bit more.
