3.0 stalls after going through puddles
8,369
Wading in 6" of water wouldn't cause a stall, driving into 6" of water at speed would cause water to splash into the engine bay fairly hard hitting the fan which soaks upper area of engine bay
Ranger850
Doesn't get Sarcasm . . .
4,685
Tallahassee Florida
Stock 2"
Stock
OOOOOhhhhhh, I see. can he put a splash guard or cover over it so it doesn't get wet? Surely something of his is missing on his truck, because nobody else seems to have this problem with such a small amount of moisture.
TheRedRanger1999
2.3Ltr
I would hit the water going maybe 15mph, and I have a fan shroud, but it's 6" up the wheel
TheRedRanger1999
2.3Ltr
Had it happen again today, when it stalled out cel light was on, no oil pressure and would just crank. Had to tow home due to starter burning out and a really bad misfire.
TheRedRanger1999
2.3Ltr
Went through large puddles fine at around 10 mph, but I hit it at 15-20 and that's when it stalled out. Will put after photos of the rowdiness in a bit
8,369
So CEL was on which means computer stayed on, not PCM relay, or computer
No start after stall could be fuel pump, but you should get a code for that unless its a problem with the pump itself, which "water" shouldn't cause.
