3.0 to 4.0 or to 5.0?
alwaysFlOoReD
5,086
Calgary, Canada
'91, '80, '06
Ford, GMC,Dodge
4.0,4.0,5.7
^^^ Have a link to that chart? The text is too small to read.
rusty ol ranger
2.9 Mafia-Don
7,489
Michigan
177 CID
Its a PDF, google "4.6 vs 460", first result
Ranger850
Doesn't get Sarcasm . . .
4,691
Tallahassee Florida
Stock 2"
Stock
Ranger850
4,691
Tallahassee Florida
Stock 2"
Stock
I'm not wanting a stupid fast street racer, just a stronger motor than before. 4.6's are way more available than the 5.o explorers. that's all.i can get a 5.0 out of a t-bird. can get the whole car running for about 500 bucks. expos go for twice or triple that around here.
Craig0320
225
Mississppi
Break it right the first time. Fix it better the next time.
Just be prepared if you get a 5.0 out of anything else other than a expo plan on shortening up the front engine accessories. The expo 5.0 has custom brackets from the factory to make it shorter. The 4.6 is a great option but I have not seen one without deleting the a/c. I did see one with the heater still working.
17,817
SW Iowa
Stock for stock a 4.6 is the same physical size as a 460, requires more wireing, and makes less HP and waaaay less torque, and pry weighs close to the same.
The 289 was actually enlarged to 302 cubic inches for SCCA(?) Racing. They had a 302 (or 305, dont remember which)limit on engine displacement, same reason chevy made the 302, and chrysler had one in that range to. IIRC vehicles were unchoked completly untill model year 72.
Ford 289/302 V8 460 late 5.0s are a bit lighter
Ford 221-302W 460
Ford 5.0 V8 450
Ford BOSS 302 500
Ford 351 Cleveland 550 includes BOSS and Australian 302C
Ford 351 Windsor 510
Ford 351 Windsor 525
Ford 351M-400 575
Ford FE 625
Ford 427 SOHC 680
Ford 429/460 V8 640
Ford 429-460 720
Ford 460 V8 720
Ford BOSS 429 680 iron block, aluminum heads
Ford BOSS 429 635
Ford 4.6 SOHC 530 iron block, aluminum heads
Ford 4.6 SOHC 473
Ford 4.6 SOHC 600 Mustang
Ford 4.6 DOHC 521 aluminum block and heads
Ford 4.6 DOHC 576
https://www.stangnet.com/mustang-forums/threads/weight-5-0-vs-4-6.395125/
The Boss 302 was made for SCCA racing and is almost a different engine from a regular 302. The plain 302 was developed for the same reason the 289 was... mo powa :3gears:
rusty ol ranger
2.9 Mafia-Don
7,489
Michigan
177 CID
Hmm, i stand corrected on weight
Ranger850
4,691
Tallahassee Florida
Stock 2"
Stock
could these brackets be fab'd or bought?
Ranger850
4,691
Tallahassee Florida
Stock 2"
Stock
281, none of that GM crap...
All the 4.6 swaps I have seen are on stock height 2wd trucks. They had a factory "full to the brim" appearing engine bay and really didn't look too bad.
any thread links or additional info on these builds would be AWSOME:yahoo:
A 4.6L weighs nothing close to a 460 big block, in fact a 4.6L weight less than a 302.
It has a similar size on the outer dimensions, but the block uses a lot less material, and the heads are aluminum, that cuts a lot of weight. If the 4.6 had been done on a smaller V it could have been the same size, or a little smaller, than a 302.
rusty ol ranger
2.9 Mafia-Don
7,489
Michigan
177 CID
But it wasnt. So you still have to do the same amount of chopping to get a 460 in, just run 3/4 ton front springs.
Not to mention even your weezing 70s 460s were making 365ftlbs, to my knowledge no garden variety 4.6 even comes close. Not to mention you can build a fire breather alot cheaper and eaiser with a 460.
Good, if you wanted stupid fast the LS engines are better.
17,817
SW Iowa
The 460 is longer though, in a tight RBV engine bay length gets tight faster than width. Coupled with the weight I would pass on a BBF.
rusty ol ranger
2.9 Mafia-Don
7,489
Michigan
177 CID
Still shorter then a 300 I6.
Either way, for the OP, just go 302
Yeah but if you don't move your firewall back 300-6 leaves you 2 inches to put fans, radiators, and any other coolers you may need in the engine bay.
