31 spline FX4 Level 2 replacement question
pjtoledo
2,953
Toledo Ohio
Fords
3.0 2.3
I think that is per, T expensive
turbo91xlt
63
Goshen, NY
1992
31 spline Ranger shafts are shorter then explorer shafts (at least the '95+ disc brake explorer axles). I recommend ditching the FX4 axle and build an explorer 8.8... You can always find replacement shafts for those in the junkyard. If you want drums then the 1st gen explorer ('91-'94) 8.8 is the ticket and the rangers parking brake cables are plug and play. There is a slim possibly the drum brake explorer 8.8 axle shafts are the same length as the FX4. There is most definitely a difference in length of the axle shaft flange to axle tube end between 31 spline drum & disc axles.
snoranger
Professional money waster
ASE Certified Tech
13,599
Jackson, NJ
'79,'94,'02,'23
All Fords
2.3 EcoBoost
31 spline Explorer axle shaft lengths:
1990-1994 axle shaft 27-3/4" long (drum brake)
1990-1994 axle shaft 30-5/8" long (drum brake)
1995+ axle shaft 27-5/8" long (disc brake)
1995+ axle shaft 30-1/2" long (disc brake)
