HardRooster
New member
- Jul 21, 2017
- 10
- Pioneer, CA
- Ford
- Engine Size
- 4.0
- My credo
- Politics is the religion of convincing yourself that the worlds problems are someone elses fault.
I have a 92 Explorer that started knocking just a few miles after I replaced the cylinder heads due to a blown head gasket. Pretty frustrating, but I'm here now, with the engine out, torn down and the damage found, spun No1 rod bearing due to a clogged oil feed hole in the con-rod. I'll get pics of all the carnage up in a few posts.
I've been researching the interwebz about this motor, and I've got an idea of what to do to rebuild this motor and give it a little more pep without making it an expensive project.
I should note, that I'll also be rebuilding the transmission, and maybe doing more work to the paint and body (I'm a professional painter/body man) if I'm feeling up to it, but those will all go in the appropriate forum sections.
Back to the motor, I've ordered up a list of parts, broken down on this spread sheet/screen shot (Updated 7/26);
Explorer Invoice2 by CASEY, on Flickr
The big difference will be the addition of the Comp Cams 410 grind, a minor port and polish job and headers. From ALLLLL the research I've done from people who've actually worked on these motors, those three changes will make a significant difference. Other things like throttle body, MAF sensor, cat-back exhaust are all back up singers on this stage. Also, those are things rather easily added later. It's much harder to go back and add a cam later.
Not listed on there is an air box modification. I'll probably do something like what I've seen in the tech section, maybe a cowl induction with a pipe run behind the fender. Just something to draw non-engine-bay-air.
So anyway, chime in with your experiences and advice, let me know if I'm missing something, or doing something needless. Pics and updated coming in the next couple hours.
