4r / 5r Shift Controller?
8,369
Need to decide on which diesel engine you want first then you can research which transmission would be best for that engine
snoranger
Professional money waster
ASE Certified Tech
13,652
Jackson, NJ
'79,'94,'02,'23
All Fords
2.3 EcoBoost
This. ⬆
Figure out what engine you want then find what adapters are available... that will dictate which trans options you have.
WantToBeDiesel
Mildmay Ontario
Ford Ranger XLT
Ok,
I have a friend who is a machinist, so he can make a custom adapter plate,
Just a matter of finding an engine, and I want to stick with a gm trans
bobbywalter
TRS Technical Staff
Ugly Truck of Month
4,668
woodhaven mi
FORD mostly
BIGGER
sawzall?
Great!
Are there any threads here on doing the tranny swap?
my vehicle is equipped with a diesel and a 4l80. mercilessly extracted from humvee and cucv carcasses.
it has a 3 inch body lift. with my particular situation.
i can install it without a body lift but it would suck to work on it. it suks to work on stock trucks without a body lift for that matter.
2wd ? 2 or 4wd and your goals are needed...
WantToBeDiesel
Mildmay Ontario
Ford Ranger XLT
Yes, mine is 2wd. I want to have a fun, fuel efficient comuter truck
WantToBeDiesel
Mildmay Ontario
Ford Ranger XLT
So how does a 6.5 diesel fit??, seems like a tight squeeze
bobbywalter
TRS Technical Staff
Ugly Truck of Month
4,668
woodhaven mi
FORD mostly
BIGGER
sawzall?
well...1.9 alh or the later 2.0 vw are outstanding platforms for a 2wd. the 4l60 oreven a 3 speed would be ok.
with a stock 1.9 keeping your 4r55 will probably be fine. getting the signals from the diesel to run the stock pcm is not likely easy....but utilizing the edis it may be possible to hack it together with just driveway ingenuity.
bobbywalter
TRS Technical Staff
Ugly Truck of Month
4,668
woodhaven mi
FORD mostly
BIGGER
sawzall?
its a matter of compromise and goals.
bobbywalter
TRS Technical Staff
Ugly Truck of Month
4,668
woodhaven mi
FORD mostly
BIGGER
sawzall?
WantToBeDiesel
Mildmay Ontario
Ford Ranger XLT
Ok,
How about a 1.6 fully mechanical tdi?
I have a lead on a good runner for $150
WantToBeDiesel
Mildmay Ontario
Ford Ranger XLT
Also,
How do I choose my shift points with a 700r4 if it’s not computer controlled? How does a megashifter work? Is it like driving a manual without a clutch?
snoranger
ASE Certified Tech
13,652
Jackson, NJ
'79,'94,'02,'23
All Fords
2.3 EcoBoost
Changing the governor springs and weights will change the shift points. They sell kits for it.
No, it's not like driving a manual... it's like driving an automatic with a floor mounted shifter. Yes you can manually shift gears, or just put it in drive and go.
bobbywalter
TRS Technical Staff
Ugly Truck of Month
4,668
woodhaven mi
FORD mostly
BIGGER
sawzall?
