5.0 swap and SAS "Half-Pint"
Rooster
20
Dallas, TX
Solid Axle Swap 4x4
I already have the paint👍😁
Rock Auto 5% Discount Code: 173A8B749AB83C Expires: January 1, 2020
Rooster
20
Dallas, TX
Solid Axle Swap 4x4
Got all of the steering parts cut out this weekend. Gonna take it to a friend to tig weld. The front dana 44 has Chevy knuckles, so it takes Chevy tie rod ends. The problem is, the gearbox is off a bronco, so I need to get the pitman arm reamed to fit a Chevy tie rod. So I either need to buy the reamer for like 80 bucks or find a shop that will do it. Haven't figured that out yet.
26725
Rooster
20
Dallas, TX
Solid Axle Swap 4x4
I also got a new tailgate this weekend. The one I had before was bent and hit the bumper when opened. I modified a tailgate off an early 90's ranger to fit my truck. Took a full day to get it to fit right. A lot of cutting, welding and hammering lol. Huge PITA, wouldn't really recommend it, it'd probably be easier to just cut out the Ford logo and weld it into a newer tailgate, but by the time I realized that I was already committed. I think it looks pretty cool though. Will have to get the dent out eventually, but for now its fine
26726
26727
Rooster
20
Dallas, TX
Solid Axle Swap 4x4
Made an exhaust system today. Didn't have any pre-bent tube so I made bends out of pie cuts. Took a long time. I kept the stock explorer cats, then there's an x-pipe into dual thrush mufflers. Has a good low rumble(y) Edit: should I grind down my ugly welds or not worry about it?
27127
27126
27128
Rooster
20
Dallas, TX
Solid Axle Swap 4x4
Got the interior somewhat put together. New vinyl floor, new (used) seats, and aftermarket speakers. Still working on the T-case shifter and other little stuff. I think Im gonna leave the back seats out and put in a toolbox or something. I have the back wall off a two door truck, gonna try and adapt it to my needs so I dont have the goofy jack mount back there
27463
27464
Rooster
20
Dallas, TX
Solid Axle Swap 4x4
Made some track bar mounts and tack-welded them in place. Still working on getting some tube bent for the track bar. Also made an engine crossmember. Bought a reamer online, that arrived today too (y)
27598
27599
27600
27601
Rooster
20
Dallas, TX
Solid Axle Swap 4x4
Painted and installed the front bumper today
27631
27632
27633
27634
Rooster
20
Dallas, TX
Solid Axle Swap 4x4
Finally got a track bar bend and mocked up! I put it together with the steering and from what I can tell I should have little to no bump steer. Ill have that tig welded at the same time as the steering linkage.
29082
29083
29084
Rooster
20
Dallas, TX
Solid Axle Swap 4x4
Also replaced the horn with a stebel nautilus. The stock horn wasn't working very well so I figured Id upgrade. Its pretty loud/obnoxious but I think I like it.
29085
Rooster
20
Dallas, TX
Solid Axle Swap 4x4
Liberated most of the parts from the explorer. Still need to get a couple things here and there. I found the rod knock, one of the rocker bolts pulled the threads straight out of the head. If anybody knows any good places to go in Dallas to get something like that fixed I would appreciate the info.
29335
29336
29337
Rooster
20
Dallas, TX
Solid Axle Swap 4x4
The 64 inch leaf spring swap made me relocate one of the brackets for the parking brake. Made a little mounting point out of some sheet metal
30409
Rooster
20
Dallas, TX
Solid Axle Swap 4x4
Wound up welding the track bar and steering linkage together myself. Track bar is installed, so no more ratchet straps holding my suspension together!
31066
31067
Unfortunately, when I was reaming the pitman arm to fit the chevy tie rods, I went a little too far, so that's a $90 part I'll have to buy again.
31068
Also connected the rear brake lines temporarily. I had to get a new line for the driver side, the 8.8 had a different size fitting on that side. When I install the 9 inch I'll do a prettier job with the lines, I just needed them functional for now.
31069
Rooster
20
Dallas, TX
Solid Axle Swap 4x4
Got a custom high pressure power steering hose made. Its the same fittings as a 94 explorer on both ends, so I tried using a hose from a 94 but it wasn't a good fit. Went to a hose fast and got one made that works. Now I just need to mount a cooler and return lines.
31070
31071
31072
alwaysFlOoReD
Forum Moderator
739
Red Deer, Canada
'91, '94, '80
Ford, GMC
4.0,4.0,350
I'm almost positive you can find a cone shaped shim.
Rooster
20
Dallas, TX
Solid Axle Swap 4x4
I’ll look into that. I already ordered the new one, but I could keep the shim and the old one as a spare
