5R55E help needed
no class
4
Can anyone tell me what the two-wire connector with the green plug is for?
32340
Dirtman
13,326
41N 75W
It's up there.
It's down there.
Round.
I poop in the furnace.
Intermediate shaft speed sensor.
no class
4
Reason I ask is I plan on using that trans (2003 5r55e) in a 1999. The 99 doesn't have that connector.
I am hoping that since the 99 has the VSS sensor on the rear diff that I don't need the ISS sensor.
Dirtman
13,326
41N 75W
It's up there.
It's down there.
Round.
The ISS sensor is used for the adaptive shift control, not for the speedo (software changed in 01 and got more complex which is why they added the ISS for more feedback). As long as you use the 99 computer it should be fine without hooking it up (I think).
Transman304
43
Morgantown WV
Chrysler PT
2.4
If you can’t fix it with a hammer, you have an electrical problem
You will be good. Not needed in a 1999 they started using that in 2001.
Brad
