'85 Ranger Restomod
17,817
SW Iowa
If you are squeamish you should just skip this post... go change the air in your tires or something.
Attacked the coil bucket with the grinder:
Now to go gag in the corner:
PetroleumJunkie412
Official TRS EV Taunter
6,565
Dirtman's Basement
2.9l Trinity
I feel you... Doing similar to mine right now.
alwaysFlOoReD
5,086
Calgary, Canada
'91, '80, '06
Ford, GMC,Dodge
4.0,4.0,5.7
Mine wasn't quite as bad. I ended up plating with 1/8" using the bucket as part of the plate. So I extended the flanges on either side of the bucket by about 10". There are pics in my build thread. Post #44
PetroleumJunkie412
6,565
Dirtman's Basement
2.9l Trinity
What we all wouldn't do to have stainless frames...
alwaysFlOoReD
5,086
Calgary, Canada
'91, '80, '06
Ford, GMC,Dodge
4.0,4.0,5.7
OOhh, even the crossmember got hit....
17,817
SW Iowa
I think the steel frame, especially on older trucks is fine. It is all the stamped brackets that are attached to it that collect moisture and debris and can’t drain. I am very temped to drill drain holes in the pocket on the spring buckets so water can drain and/or I can hit it with a blow gun and blast the crap that collects in them out the top. Otherwise it can only sit in there and fester.
PetroleumJunkie412
6,565
Dirtman's Basement
2.9l Trinity
Good point.
However, my internal monologue says":
stainless = less susceptible to rot
less susceptible to rot = less washing
Less washing = I can be lazy
I can be lazy = win!
17,817
SW Iowa
Stainless can be kind of funky, softer than steel and can still rust.
Bird76Mojo
1,265
IL
Softer than steel? Huh?
Ranger850
Doesn't get Sarcasm . . .
4,691
Tallahassee Florida
Stock 2"
Stock
17,817
SW Iowa
I was in a hurry and didn't finish my thought. Thought was dollar for dollar it is softer and all around IMO inferior, especially for something as massive as a truck frame. And it still rusts especially in a salt bath and pummeled by road debris.
For example to make up the price difference for example most hardware SS fasteners are like less than grade 2 to make it seem more on par with grade 5. So it is soft and breaks easy. It took no effort to snap a hardware store SHCS I was trying to use as a valve cover bolt (clear to back on passenger side, good time digging that out)
ARP stainless bolts are a different grade... and different price. Which is what i have for my valve covers, intake and new differential cover. Costs a lot more than hardware store junk but I have yet to break one (knocking on wood)
Bird76Mojo
1,265
IL
Then why is stainless steel so resistant to drilling with hardened steel drill bits if it's softer?
Try to dent some 1/4" stainless sheet with a hammer. Now, try to dent some 1/4" mild steel sheet with a hammer. Guaranteed, the stainless is harder. It certainly resists rust for FAR longer than mild steel as well, and with nearly any grade of stainless alloy, it will easily outlast any of us, even if left outdoors for it's entire life.
Most stainless steel alloys don't rust easily at all unless you introduce an inferior metal in to it via welding.
It's also much harder to bend/shape/form, and it also work-hardens much faster than mild steel.
Sorry man, but I'm not buying it. I worked with stainless steel alloys in a production environment for decades, as well as both hot/cold rolled mild steel, and several aluminum alloys. Stainless steel is superior to mild steel in every way where longevity is concerned.
Ranger850
4,691
Tallahassee Florida
Stock 2"
Stock
In my experience (nut & Bolts) we used stainless 1/4-20 bolts with aluminum frames, for the anti-rust factor, not for how strong they were. ( a lot of beach home owners have awnings). The stainless bolts would snap way before the mild steel ones. Never stripped or cross threaded a stainless bolt either (they break before reaching this point), while I have pulled the threads off numerous bolts hat were NOT stainless. I do not have much experience with the sheet metal aspect of it though.
17,817
SW Iowa
Because like carbon steel there are different grades/kinds?
Interesting that SS gunbarrels are generally more accurate than carbon steel because they are easier to machine precisely... but they don't last as long.
There are different kinds of stainless, some are softer and more corrosion resistant which is what most normal people encounter. Pans, silverware, gunbarrels, cheaper hardware etc. The better stuff is harder to work with, not as corrosion resistant and more expensive.
PetroleumJunkie412
6,565
Dirtman's Basement
2.9l Trinity
...chaos caused, mission accomplished. ?
