- Aug 22, 2012
- 78
- Southwestern Idaho
- Ford Bronco II
- Engine Type
- 2.9 V6
- 2WD / 4WD
- 4WD
- Total Lift
- 0
- Total Drop
- 0
- Tire Size
- 205/75-R15
- My credo
- 19K, 19D, 92Y, 91F
Does anyone know by chance what length speedometer cable the Bronco 2 uses with the automatic transmission, and a good place to order one. Seems mine is bad. It would stick at 0mph for a while then jump up to the correct speed...then this morning it did the same except it went all the way around to 85mph then after that it has been about 15-20mph off all day so I'm assuming the cable is bad. Also, are the gears for the speedometer cable still available somewhere? I need to find an easier to access tire size for my Bronco 2 so I'm thinking of going with 235/75-R15's so I'll of course need to change the speedometer gear...that is if they're still available somewhere, and which one I need...currently it has 205/75-R15's.
