88 ford ranger Door Glass
DRE88
Palmetto Fl
Does anyone know if the door glass is the same between an 88 and 89 ranger? with out vent windows?
8,369
Yes, doors are the same, so is the glass, assuming same side
DRE88
Palmetto Fl
according to Ford the glass is not compatible with the 89?
Dirtman
13,326
41N 75W
It's up there.
It's down there.
Round.
I poop in the furnace.
What does ford know...
snoranger
Professional money waster
ASE Certified Tech
13,621
Jackson, NJ
'79,'94,'02,'23
All Fords
2.3 EcoBoost
bobbywalter
Ugly Truck of Month
4,668
woodhaven mi
FORD mostly
BIGGER
sawzall?
there are offsets in the panel styles and how the reg hooks up power to manual...had to open the holes a little and used custom fasteners.
DRE88
Palmetto Fl
so the glass will fit the only problem is how it mounts to the window regulator? i have manual crank windows. do you have any pics of what you modified?
bobbywalter
Ugly Truck of Month
4,668
woodhaven mi
FORD mostly
BIGGER
sawzall?
no. i dont think so. i might be able to pop the card off and see if its pictureable....but i suk at pictures.
its self explanatory if your changing hardware.
bobbywalter
Ugly Truck of Month
4,668
woodhaven mi
FORD mostly
BIGGER
sawzall?
no....not a two minute deal......have to pull the armrest and crank and handle insert...i gawked down from the top with a light and i cant see much.
i plan on new regulators track and seals this year....so that would be when i would make pics....unless i blow another window out first....
but i have 92 windows in 85 doors on my 88 ranger with mangled cab.
Dirtman
13,326
41N 75W
It's up there.
It's down there.
Round.
Have brick, will travel!
bobbywalter
Ugly Truck of Month
4,668
woodhaven mi
FORD mostly
BIGGER
sawzall?
i destroy windows. its why i have tube doors.
Nez'sRanger
68
Pennsylvania
2.9L V6
I put the vent/wing windows from a 85 bronco ii in my 89 ranger, which fit like a glove, btw. All I had to do was drill out a hole to secure it, but lo and behold, there was a dimple in the metal exactly where the hole needed to be. All I had to do was cut away a bit of the door skin to accommodate the wings. When I got the new glass for the roll up, it fit in perfectly. The holes lined up with my original manual crank.
All that to say, I agree with RonD!
