88 Ranger diesel swap
Sling
Vineland, nj
I am looking into an 88 ranger and wanted some insight on what might be the cheapest, yet most efficient diesel to put in it. The ranger has a 5-speed trans in it that i do not plan to change if possible.
A 4D55 is going to be the easiest, probably. A VW TDI engine is probably the best for efficiency. If I was going to do this (I really want to do this) I'd look for a 4BT, that that is a whole different can of worms. There is nearly a 120% chance you will need to change the transmission though.
snoranger
Professional money waster
ASE Certified Tech
13,622
Jackson, NJ
'79,'94,'02,'23
All Fords
2.3 EcoBoost
While I do agree with adsm that the 4bt is a good choice, there is nothing cheap about it. They're expensive to buy, usually $2k +. They can destroy any Ranger trans in a matter of seconds, trans and T case(depends on 2 or 4wd) swap needed. They tip the scales at or above big block weight, which means suspension upgrades just to install it. They are poorly balanced and will shake, rattle, and roll. BUT... the sky is the limit with the power you can make.
If I were to build a diesel Ranger daily driver, I'd use a VW diesel.
I had a 4bt in an Explorer... the front diff couldn't handle it. I was making 5-600 lb-ft of torque. So I pulled it and junked that body. Now it's going supercharged over turbocharged to motivate my '79 F350 supercab, complete with 06+ Superduty axles and suspension.
Dirtman
13,326
41N 75W
It's up there.
It's down there.
Round.
I poop in the furnace.
I can't think of any diesel that will work with your stock trans so you might as well face reality on that.
17,768
SW Iowa
FWIW you could get a diesel in a first gen... not a whole lot of power though.
bobbywalter
TRS Technical Staff
Ugly Truck of Month
4,668
woodhaven mi
FORD mostly
BIGGER
sawzall?
4d55. if it has the toyo there is a bell for it.
