'90 ranger 2.9l dead again
Redranger90
Powell River B.C.
Fuel, air, spark... Missing one or one isn't getting there when it needs to be.
My gut reaction is a dead fusible link somewhere, broken ground, dead tfi, or distributor spun around.
Can you pull trouble codes?
How will i know if the fusible link is dead ?
Redranger90
Powell River B.C.
Well its home now....drove home on its own power. Definitely electrical related,The pump relay only worked for the injectors so i bypassed the EEC to the pump by jumping the pump test port with a wire and she started up.
When i got home though i disconnected the jump wire and to my surprise the relay now works for the pump. So now i have to find out why its intermittent. A short is likely but where to start looking is the question.
Uncle Gump
Token Old Guy
13,442
Ottawa IL
Ranger/BroncoII
4.0L SOHC/2.9L
There are some schematics in the How to Tech section that most likely cover your vehicle...
Not so sure you're looking for a short as much as a poor connection that reconnected with the messing around you did. I would look at the engine controls schematics and retrace what you did to make it run... then go from there.
rusty ol ranger
Im a Jeep guy now.
7,430
Michigan
177 CID
Check the connector where the pump relay plugs in.
