'93 Manual Locking Hubs - Newb Questions
projectRanger93
Active member
167
Los Angeles, CA
Ranger STX
235/75-R15
I'm missing the manual locking hub mechanism (the guts) on the driver's side, it was gone when i got the truck. I just have the "shell."
My questions are the following:
1.) Can i still dive the truck in 2wd with it missing? Would that cause any issues?
2.) What is the original brand, Ford/Motorcraft or someone else?
3.) What brands do you recommend or would advise not to get?
4.) I know the hubs can be interchanged in the 93 - 97 years. Am I able to switch it out with older versions?
5.) If i get a replacement, is it advised to switch out the passenger side too or it doesn't matter?
Feel free to answer whatever you can.
Thanks!
Rock Auto 5% Discount Code: 173A8B749AB83C Expires: January 1, 2020
Uncle Gump
Well-known member
898
Plano IL
Lead, Follow or get out of my way
Just get a set of Warn hubs for your year and replace both sides... keep the other for a spare.
1,476
I agree with Gump.
The originals would have been branded as Ford, but I don't know who made them.
Warn is a great brand, but they only sell them in pairs, so get both and put them both on. It is safe to drive like that for a while, but not indefinitely.
The alternative is to gamble on a JY unit, which they are pretty sturdy and rarely fail, so might be worth it.
projectRanger93
Active member
167
Los Angeles, CA
Ranger STX
235/75-R15
Thanks guys! Yeah the Warn would definitely seem more enticing if it was half the price :LOL: but maybe I'll bite the bullet. Thanks for the advice.
Denisefwd93
Well-known member
54
South East PA
Thanks!
Replace both with Warn and be done. Bad or parts missing just mean trouble but you should probably be able to drive it in 2wd, does your shift motor work?
projectRanger93
Active member
167
Los Angeles, CA
Ranger STX
235/75-R15
I have a manual transfer case, so happily don't have a shift motor.
4x4junkie
Forum Moderator
179
So. Calif (SFV)
2.9L V6
35x12.50R15
The factory hubs were made by Warn, and have a narrow "4x4" decal on the dial knob.
Any 27-spline hubs made for the Dana35 axle should fit yours (year range is from mid-'90 to '97 models and includes '91-'94 Explorers).
Mile Marker is the only brand I might suggest to avoid... In the past there were numerous reports of them breaking in use, though I also have to say I've not seen anything real recent (not sure, maybe they changed the design).
If you have any plans to add a front differential locker and oversize tires, I'd suggest going a step further and get the Warn pt# 37780 hubs, which are considerably stronger than the standard-issue Warn #29071 hubs.
Forum Moderator
1,709
SW Iowa
JY, Explorers have them. Locally they are $9.99/pr and they don't care if the bearing nuts/washers are in the hubs or not.
projectRanger93
Active member
167
Los Angeles, CA
Ranger STX
235/75-R15
I found hubs off a 91/92 ranger. They'll fit right?
28999
29000
scotts90ranger
Well-known member
76
Dayton Oregon
2.3 Turbo
They should, as long as the pumpkin has 10 bolts on the front of the beam it's for a Dana 35 which should be factory on any '90.5 to '97 Ranger, but you never know what people put in after the fact...
racsan
Well-known member
286
central ohio
1994 (mostly)
2.3/140-4
built, not bought
I did run mile marker’s and only had a issue once, I was backing into a parking spot in the winter. There was plowed snow pushed into the parking spots on this back row, I didn’t like how far the nose of the truck stuck into the drive so I tried backing up into/on top of the snow pile. Of course the back tires started slipping once the hitch and back bumper started pushing snow and the rear tires themselves were on snow. Hubs were already locked in as there was quite a bit of snow that week. I put it in 4L and went back some more, front tires were on clean pavement. Well after about a foot & a half of travel there was a loud “pop” from the front. No more help from the front axle. When I checked things out later the drivers side hub had broke the large engagement ring - in 3 places! I got another set and had a spare then. Was the only problem I ever had with mile marker. I did have issues with the stock auto hubs, more than once they didn’t want to engage.
projectRanger93
Active member
167
Los Angeles, CA
Ranger STX
235/75-R15
I think I will be going with new ones. I wasn't convinced with getting the JY ones in the end because i've had mixed experiences with JY parts. I would rather not deal with failing parts in the near future, so eh screw it i'll go with new.
projectRanger93
Active member
167
Los Angeles, CA
Ranger STX
235/75-R15
Anyone familiar with the brand Ultra Power? Looking at the ULTRA-POWER 600212 off rock auto right now.
wildbill23c
Well-known member
82
Southwestern Idaho
Ford Bronco II
205/75-R15
19K, 19D, 92Y, 91F
No experience with the Ultra Power, or Warn hubs, I have the Mile Marker Hubs on my 88 Bronco 2, no issues with them. Had the passenger side hub decide that making odd clattering noise was the result of trying to use the 4WD, so I replaced both hubs with Mile Marker brand hubs and they've been working fine for what little 4WD use my Bronco 2 sees. Some of the knock off names kind of make me stray away, stick with Mile Marker or Warn and you'll be fine. Might cost a couple bucks more but at least you have a part the company will stand behind and more than likely lend assistance with if it breaks or other issues.
projectRanger93
Active member
167
Los Angeles, CA
Ranger STX
235/75-R15
Thanks for the input! Ultra Power is a brand sold from Rock Auto. I guess I'll go with Warn when more funds become available.
