97 5 Speed Stuck in reverse
Kroeter
Ohio
V6 4.0
My 97 Ranger is now stuck in reverse. The gear shift is in neutral and will not go into any gear but the transmission stays in reverse. With the clutch in it will roll.
Had a new clutch put in not too long ago!!!
tx3nc
3.0L V6
I doubt the problem is the clutch.
I would start by pulling the shift lever and then take the shifter 'ball' (the part the lever is bolted to) out and see if it is broken. There should be a short lever on the bottom of the ball that engages the shift rails. My first guess is that might have broken off when you were in reverse.
If that is not the problem, then the trans might have to come out so you can pop the top off and see what is going on inside.
If it is stuck in reverse, can you engage any other gear? If you are able to, that will lock the transmission and nothing will turn. If you can do that then the shifter ball is probably ok and the problem could be in the shift rail for the reverse gear.
It also occurrs to me that the reverse/5th shift fork is on the bottom of the transmisson and is activated by a lever that is bolted to the driver's side of the transmission case. If the problem is in that linkage, then you should be able to shift into another gear and lock the transmission up.
BTW, I would NOT test the transmission lockup by engaging engine power. I would jack the rear end up and try turning a rear wheel or drive shaft.
Kroeter
Ohio
V6 4.0
Mechanic friend got in from the top and popped it out from between gears with a scewdriver. said it was stuck between gears?? I'm not real knowledgeable of the transmission but it has been back up and running for a couple months. 240,000 and still going.... KNOCK ON WOOD!!!!!!!!!
onecoolone
missouri
ford ranger
i have same proble4m only i cant get it out of gear
8,369
Welcome to TRS :)
You should start your own thread(post)
Assuming a manual transmission
If you have a 1989 2WD 4cyl or V6 Ranger you will have a M5OD-R1 transmission OR as Mitsubishi FM132
If 4x4 then will be a Mitsubishi FM146 transmission
You need to pull out the shifter and have a look inside
You should see 3 shift rails, 1-2, 3-4, 5-R
All 3 must be in the middle(neutral)
And truck should then roll with out clutch pedal in
If a shift rod breaks or shift fork then trans will be stuck "in gear" because that shift rod can't go to Neutral(center)
Transmission is designed so only 1 shift rod can be "in gear" at a time, it must be moved back to Center before a new gear can be selected
scotts90ranger
4,329
Dayton Oregon
2.3 Turbo
I agree. Assuming an M5OD (like Ron said if a 4 cylinder (all 4 cylinders after '88 were M5OD) or some V6's) if you pull the shift boot (4 screws) then the nut on the bottom of the shift lever and tighten it on the other side to undo the pinch bolt the shifter will come off, from there I think you can see the 3 screws on the shift seal, take those out then the shifter will pop out and you can see the shift rails like Ron is talking about.
No members online now.
