98 5.0 oil filter thread replacement
Ramcharger90
1,708
N/A na
306, Bcam,
So I have been putting my 5.0 together for the swap. From a 98 mountaineer and I just realized the threads are on the inside of the oil filter location and since I doubt I can use that antifreeze cooled 90° that was on the engine due to my 1990's steering box location what should I do here? I know I need to relocate the oil filter but how do I change over to a traditional thread style on those 5.0's
fastpakr
2,832
Roanoke, VA
Have you looked at the later oil filter adapter? I don't know if it works better for your swap, but the 99 version is shaped differently and not liquid cooled.
19Walt93
4,464
Canaan,NH
351
3"
235/55R16
There's an adapter that threads into the hole on 302's with engine mounted filters.
Ramcharger90
1,708
N/A na
306, Bcam,
I was going to get the one from transdapt or something similar I know since im putting it in a 90 ranger I dont think its gonna fit using the other style 90
Ramcharger90
1,708
N/A na
306, Bcam,
So he is an update its really easy to remove the exploder oil filter thread use a 1 1/4 socket ill update when I install the other one it only comes tomorrow
