- Aug 10, 2014
- 22
- Age
- 31
- Madison, IN
- Ford Ranger
- Engine Type
- 4.0 V6
- Engine Size
- 4.0L
- 2WD / 4WD
- 2WD
- Tire Size
- 215/70R15
My A/C had a sudden leak. Long story short, the threaded connection between the accumulator and evaporator came loose or something and loudly vented.
Background:
I'm doing some A/C work to correct a slow leak today. I suspected faulty O-rings in the low pressure line's connection to the Accumulator; I redid the O-rings last fall and it never did seal correctly.
Anyway, I swapped accumulators, adding 6 oz of PAG 46 oil. I replaced all 4 O-rings while I was at it using spares from last fall. I put it all together and Vacuumed it out for a few minutes until I got it to -27mmHg, and let it set for 30 minutes. During that time the pressure rose to -20mmHG, But I charged it with 2 12oz cans of R134a in hopes of being able to use my sniffer to find the leak.
The AC worked great for the 15 minutes I ran it to see my pressures. I shut it off to do a sniffer test, and while I was powering up the sniffer HISS!!!! Very loud leak at the threaded connection between the accumulator and evaporator. Lots of dye/oil mix came out too.
I had the connection tight and all... Bad O-ring? Or is something else to blame?
I did notice that the accumulator and evaporator didn't want to line up straight... maybe that's related?
Suggestions?
Background:
Suggestions?
