Acceptable ring gear pattern?
mastermechanic5
New member
Fairfield, CT
Hi guys,
I'm setting up gears in my Dana 44 and need a little guidance. I tried adding and subtracting pinion shim while keeping my backlash within the 0.006-0.008" range and so far this seems to be my best pattern. Is it ok that the pattern is high on the coast side? Thanks!
Rock Auto 5% Discount Code: 173A8B749AB83C Expires: January 1, 2020
sgtsandman
Well-known member
601
Aliquippa, PA
2011 & 2019
Ford XLT & FX4
4.0 SOHC & 2.3 Ecoboost
31X10.5R15 & 265/65R17
From every thing I’ve seen, that is considered acceptable. Not ideal but acceptable.
ericbphoto
Old Redneck just wingin' it.
1,133
Wellford, SC
6"
I would drive it.
Dirtman
Well-known member
EMT / Paramedic
2,415
Over there --->
466.63 teaspoons.
So friggin big!
Give me money.
If it's a front axle I'd call it a day and run it, if it's a rear axle I'd try to get the coast side closer to the toe... but either way it's really not bad.
mastermechanic5
New member
Fairfield, CT
Alright I'll run it. Thanks for the input! Now time to setup my 9" for the rear :)
19Walt93
Active member
159
Canaan,NH
351
After doing a Dana the 9" is going to seem too easy.
