Acceptable ring gear pattern?
mastermechanic5
Fairfield, CT
Hi guys,
I'm setting up gears in my Dana 44 and need a little guidance. I tried adding and subtracting pinion shim while keeping my backlash within the 0.006-0.008" range and so far this seems to be my best pattern. Is it ok that the pattern is high on the coast side? Thanks!
sgtsandman
Aircraft Fuel Tank Diver
U.S. Military - Active
Ham Radio Operator
12,572
Aliquippa, PA
Ranger XLT/FX4
4.0 SOHC/2.3 Ecoboost
Pre-2008 lift/Stock
31X10.5R15/265/65R17
From every thing I’ve seen, that is considered acceptable. Not ideal but acceptable.
ericbphoto
Overlander in development
16,530
Wellford, SC
3.0L
6"
I would drive it.
Dirtman
13,326
41N 75W
It's up there.
It's down there.
Round.
I poop in the furnace.
If it's a front axle I'd call it a day and run it, if it's a rear axle I'd try to get the coast side closer to the toe... but either way it's really not bad.
mastermechanic5
Fairfield, CT
Alright I'll run it. Thanks for the input! Now time to setup my 9" for the rear :)
19Walt93
4,462
Canaan,NH
351
3"
235/55R16
After doing a Dana the 9" is going to seem too easy.
