adding extended radius arms pls help!
CamSmdz
Ford ranger
4 inch lift
So I have the 4 inch rough country suspension lift and want extended radius arms and I see some kits without a custom cross member. My question is do some kits not need a new crossMember or what’s the deal I’ve been trying to find instructions but the arms in particular are the skyjacker red ones, tuff country, or pro comp ones that don’t come with a cross member and not require crazy fab work like that. I like the idea of not having to mess with that .......please enlighten me!!!!
Bird76Mojo
1,264
IL
Have you checked out the stuff on JamesDuff?
Jim Oaks
Just some guy with a website
Administrator
Founder / Site Owner
Supporting Vendor
8,463
Nocona, Texas
4.0 / 2.3 Ecoboost
6-inches
33x12.50x15
Is there a reason you don't want to use the Skyjacker arms and cross member? It's not a difficult swap.
CamSmdz
Ford ranger
4 inch lift
Well I don’t exactly have the most tools and not too familiar with welding if there’s any instruction links or any advice on the whole process?? and would doing this cause the need for extended brake lines? I know I can get it done right and do what ever it takes but it sounds nice not having to mess with it
snoranger
Professional money waster
ASE Certified Tech
13,494
Jackson, NJ
'79,'94,'02,'23
All Fords
2.3 EcoBoost
There's no welding involved with the SJ kit. The new crossmember replaces the trans crossmember. You just have to grind/drill the rivets off and use the existing holes. Depending on the year, you may have to drill a couple extra holes.
Skyjacker radius arm install
CamSmdz
Ford ranger
4 inch lift
Sweet man thanks ?? But are there any kits that don’t come with new cross members because I see some without what’s up with that
snoranger
ASE Certified Tech
13,494
Jackson, NJ
'79,'94,'02,'23
All Fords
2.3 EcoBoost
IDK. I ran the Skyjacker arms on my Ranger then swapped the lift into my Explorer. I never tried the other arms.
I can tell you that anything you find will at least have brackets to mount to the frame... you can't make the arms longer and still mount them to the same location on the frame. The only thing that mounts to the stock location are drop brackets.
CamSmdz
Ford ranger
4 inch lift
Have you thought about a heim option? Or heard of one like that
CamSmdz
Ford ranger
4 inch lift
Well it seems like it would be easier to go without messing with it because I can always make something happen but if it’s not recommended to run without relocating it I’ll suck it up
ericbphoto
Overlander in development
16,275
Wellford, SC
6"
"extended" radius arms can not mount to the original frame location because they are too long. That's why the Skyjacker kit gives you new brackets and transmission mount that all fit together in one nice neat assembly. The design of those 3 pieces ( 2 brackets plus cross-member) provides a good mounting place for the radius arms and the cross-member ties the brackets together for added strength.
Kirby N.
March Truck of The Month
