Axel question
Asagarner22
Altus, ok
Ranger edge 4.0
I have a 03 edge 4.0 with a 8.8 rear end 4.10 gears would the axel shaft from a 07 ranger 7.5 rear work in my 8.8 I've read it should bit I want to be sure thanks in advance #rangernation
sgtsandman
Aircraft Fuel Tank Diver
12,642
Aliquippa, PA
Ranger XLT/FX4
4.0 SOHC/2.3 Ecoboost
Pre-2008 lift/Stock
31X10.5R15/265/65R17
As long as the wheel base and transmission are the same, it should. I would strongly recommend comparing it to what you have now before you buy. The old one has to come off anyway.
4x4junkie
583
So. Calif (SFV)
2.9L V6
35x12.50R15
They should be the same, regardless of wheelbase and transmission.
What is important is that you're on the same side of the '92-'93 width changeover date ('93+ being wider), and that it's for the correct side (left or right).
A '07 shaft should fit a '03 no problem (as long as neither are an FX4 model with the Torsen 8.8" axle).
Welcome to TRS.
sgtsandman
12,642
Aliquippa, PA
Ranger XLT/FX4
Pre-2008 lift/Stock
EDIT: I somehow completely misread the question some how. A 7.5 should swap out with an 8.8. Depending on what brakes you have, You might need to swap them over to the new axle. Possibly the pinion flange. Though those tend to be the same most of the time but I have read where people found the flanges to be different.
4x4junkie
583
So. Calif (SFV)
2.9L V6
35x12.50R15
It looks to me he just wants to change out a rear shaft, not the whole axle. (guessing worn wheel bearing journal or bent flange).
7.5" and 8.8" axle shafts will interchange, as long as the criteria I mentioned above is met.
ericbphoto
Overlander in development
16,593
Wellford, SC
6"
Axel
And to prevent further confusion...
Axl
Asagarner22
Altus, ok
Ranger edge 4.0
I was tboned and impact bent my axle just slightly but I'd rather change it now then deal with worn tire or it damaging axle itself
ericbphoto
16,593
Wellford, SC
6"
That's smart
Asagarner22
Altus, ok
Ranger edge 4.0
Welcome to TRS.
Thanks for your time appreciate it alot
Ranger850
Doesn't get Sarcasm . . .
4,691
Tallahassee Florida
Stock 2"
Stock
Lmao no one cares about your grammatical correction
not true. some enjoy it, but i need it. lol he does it to keep confusion at bay ...
and to be the whole A
