axle bearing removal, stubborn, grinding method
pjtoledo
2,964
Toledo Ohio
Fords
3.0 2.3
the bearings in a '99 were a pain to get out. puller did no good, at least not my puller.
broke the sides off with a chisel and commenced to grinding.
cutting a diagonal line with a small cut off wheel wasn't working, could not see the depth of the cut nor reach the inside.
I found that a 1/4" cylinder on a hi speed Dremel did OK. cut at a straight angle and could monitor the depth.
when it was down to paper thin it popped and then I removed it with fingers. almost no damage to the housing bore.
as always, your method may vary.
29511
29512
29513
Dirtman
13,326
41N 75W
It's up there.
It's down there.
Round.
I poop in the furnace.
Been there and done that! I picked up a 10 pound slide hammer a while back and have yet to have a bearing say no to that thing though!
pjtoledo
2,964
Toledo Ohio
Fords
3.0 2.3
I had an "improvised" slide hammer, AKA threaded rod with big washers. a real one is now on my shopping list.
4x4junkie
583
So. Calif (SFV)
2.9L V6
35x12.50R15
Gotta do what you gotta do.
I made this little gem for mine... So far it has worked every time.
