B2300 running weird! HELP!
Invisity
Billings mt
Mazda b2300
Help guys! So heres the low down. My 96 (i think) Mazda b2300 is running weird. It will rev to high rpms when the pedal isnt all the way to the ground but when pushed to the floor it stumbles and backfires amd stays at low rpms. This is what it does.
. when you mat the pedal to the floor it just backfires continously and wont go above a certain rpm.
. when driving down the road and it reaches either a certain rpm or speed (idk because it doesnt have a tach) it bogs down and losses all power just like when you floor it.
The truck has a stored code for p1443 which says: evaporative emission system control valve low/no flow. So i tried correcting that by fallowing all the vaccum hoses in the entire engine bay and all the vacuum hoses that run to the charcoal box and they all looked fine. I then replaced the solenoid or purge valve or whatever you want to call it with a new one from the parts store. But that did not solve my problem. As soon as i bought the truck a few weeks ago it was having this problem. When i first got it i tried doing a full tune up and replacing the pcv valve and those both didnt work. Then i thought maybe the cat is clogged so i cut it out and that still didn't solve my problem. So to summarize what i did already ive:
. checked for vacuum leaks.
. cut out the cat.
. checked the timing.
. replaced plugs and wires.
. replaced pcv valve
. replaced evap purge solenoid.
If any has any info im missing or think they have a possible solution please let me know. The pickup is so bad i dont even drive it! Ps since just now replacing the solenoid ive only driven it 4 miles and its still running extremely bad. Also the check engine light never came on for any of these codes i juat had it read because it was running terrible. Maybe my check engine light bulb is out? Is there a way to test that?
Uncle Gump
Token Old Guy
13,437
Ottawa IL
Ranger/BroncoII
4.0L SOHC/2.9L
First off... breath
Next question... What engine is in it. Can we start there?
Invisity
Billings mt
Mazda b2300
2.3 4cyl thats why its a b2300 haha
Uncle Gump
Token Old Guy
13,437
Ottawa IL
Ranger/BroncoII
4.0L SOHC/2.9L
Oh... that Mazda thing
So ya cut it up...
Replaced some other stuff...
Have ya checked fuel pressure?
Invisity
Billings mt
Mazda b2300
That i have not done yet. But why would it rev normally at half throttle but not full?
Uncle Gump
Token Old Guy
13,437
Ottawa IL
Ranger/BroncoII
4.0L SOHC/2.9L
Improper fuel delivery... if you aren't getting the right fuel pressure... it won't meet the engine demands.
It almost seems you might be dealing with a vacuum leak too.
Edit... What I'm saying is... before you throw any more parts at this thing... do a few simple checks.
Invisity
Billings mt
Mazda b2300
already checked for vaccun leaks. Gonna grab a fual pressure tester tonight and get a reading. What should the psi be at at idle and revving etc?
Invisity
Billings mt
Mazda b2300
update. i dont know if its the fuel pressure or not because when i hook up the fuel pressure tester to the schrader valve at the fuel rail i also have to use an adaptor for this year ford. with that being said i have hooked it up and it says theres no fuel pressure. i think thats a problem with the tester because i took the fuel filter off and had someone turn the ignition on and it shoots a bunch of fuel like a hose. also after changing the fuel filter its a tiny bit better but it still stutters until warm and at full throttle it always breaks up. tia
Bird76Mojo
1,265
IL
I'm not sure on the specs for that exact year/model of truck but I would suspect the fuel pressure should be a minimum of 30 to 35psi at idle. My suggestion is to buy a Haynes manual for your truck if you expect to own it for long.
Dirtman
13,326
41N 75W
It's up there.
It's down there.
Round.
I poop in the furnace.
Your getting no where unless you get a fuel pressure reading...
91stranger
512
Gets Mo Chicks
Have you tried just pressing the needle at the Schrader valve when the fuel pump turns on when you first turn on the key? The gas should easily hit the hood if you have good pressure. The initial symptom does sound like a bad fuel pump though. I see its a 96 so it's plenty old enough. How many miles? No matter how smart computers are they still don't tell you when your fuel pump is bad,,,,, they will tell you about every evap and oxygen sensor though lol.
