battery terminal
Which battery terminal is best
  • Marine battery terminal with brass plated wing nut
    Votes: 6 46.2%
  • Tsunami 24K gold plated negative battery block terminal
    Votes: 5 38.5%
  • Other, please post your choice with pics
    Votes: 2 15.4%
  • Total voters
    13
Doom's Day Custom
New member
5
nj
4.0l
I want to change out the battery wires and the battery terminals on my 96 ranger.. I bought and used the Scosche High Power Gold Battery Terminal and let me tell you i had so many problems... I would go to the store and shut my truck off and then come back and start the truck back up and all i would hear is click and then i would have to go over and move the terminals and then it would start right up.. Don't matter how many times i would clean the terminals and then remount and wait a while and then it would happen again...So i got rid of them and now i want new ones and i not sure if the marines ones wing nut won't come off or if the Tsunami 24K gold plated battery block terminal where any good .. So my question would be which one to get and won't give me and shit and has anyone used the
24K gold plated negative battery block terminal before??? I am also running offroad lights and hope pretty soon a winch or more offroad light..
Walmart
Scosche High Power Gold Battery Terminal, UBT-1
AUTOZONE
Price -$14.99
Any parts store
Price- $5.00 per pair
Thanks ahead of time
Jay
Rock Auto 5% Discount Code: 173A8B749AB83C Expires: January 1, 2020
Captain Ledd
Well-known member
37
Michigan
302, 2.3
If you're not making mistakes, you're not learning.
Honestly I haven't had too many problems with a basic, super generic terminal clamp.
Mr99Ranger
New member
West Virginia
2.9
I'm cheap, so I'd probly just go to the junk yard and pick up a set off a lower mileage truck.
bmonee5
New member
Oregon
ya i just bought some 1.99 specials at my auto store, paid 4 dollars total....and i'm in good shape right now i'm just gonna keep an eye on them and make sure it doesn't corrode...
88_Eddie
Well-known member
155
Raleigh, NC
2.9L, 4.0L
if you keep a basic socket set, some pliers and wire cutters in your rig, the basic cheapo connectors work fine...you can always have an extra set in the car for just in case.
Doom's Day Custom
New member
5
nj
4.0l
I am trying to do it once and the right way and not have to worry about!!!!
Spowerback
Banned
California
FORD
v6 4.0L /
audio terminal ...These 4 Wire Gold Battery terminals will accept one 2GA , 4GA cables and two 8G cables Positive
Ranger Dave (B25)
Well-known member
131
RFD/BNA/PHX
'10
Don't vote Democrat.
You don't need $16 MIL-SPEC terminals, gold plated bling or any of that other silly shit.
Get standard cable/terminals and a set of treated felt washers: clean the battery posts with corrosion remover, rinse, clean again, rinse again and install the washers, then the terminals. Coat the whole assembly in battery connection sealant (the red spray) a time or two, and ANY time you break the sealed connection, re-seal it. Keep the top of the battery clean to keep the corrosion down.
That's all you need to do. Period. If you want longer bolts to add more connections, do that, just make sure they and the nuts are stainless.
lil_Blue_Ford
Well-known member
Forum Moderator
86
Butler, PA, USSA
4.9L
I've experimented with several different battery terminals but never tried any of the gold plated fancy ones.
I have come to hate the cheap lead ones, after awhile they always seem to get badly deformed and need to be replaced. Plus the factory pressed on ones never seem to have enough places to tap onto for accessories.
My Ranger came factory with these sorta stamped steel looking things (I think they're nickel plated brass or the like). They worked pretty good and I started replacing terminals on my trucks with ones that looked the same from Wal-mart.... bad idea.... I can't tell you how many of them I've had crack before I wised up (at least a half a dozen). I also had one corrode to junk in short order. Chinese junk...
I have now progressed to experimenting with the brass marine terminals you can find at Autozone that look a lot like a cheap lead terminal but have a wing nut. Then I've put lugs on all the wires and stuck it on. Makes it easy to add another wire at a later point. I've also put a regular nut on with a lock washer instead of the wing nut. So far so good.
One other thing I've done before is to coat the terminal and the battery post with dielectric grease, it seems to work adequate for deterring corrosion.
kimcrwbr1
New member
35
maplevalley WA
2.8l
would dielectric grease help protect the connections from corrosion from dissimilar metals
lil_Blue_Ford
Well-known member
Forum Moderator
86
Butler, PA, USSA
4.9L
Not sure... I use it on all automotive electrical connections though and it seems to discourage any sort of corrosion.
Ranger Dave (B25)
Well-known member
131
RFD/BNA/PHX
'10
ASMODEAN
New member
16
El Dorado AR.
2.9 litres of ticking fury
I cant remember what the brand is, but i have a set of quick connect marine style battery terminals from orileys on my BII.
Here's a pic of the battery and connectors.
sorry for the crappy pic it's from my cell phone.
As for corrosion I use the red stuff that you spray on the backs of brake pads to stop them from squeaking on the bottoms of both terminals.
MountainMike
New member
82
Yukon
245 CID
The fun begins where the pavement ends
Those look like bike seat clamps... that's kind of cool
I would recommend a set of cheapo autostore marine-style terminals. Easy on the wallet and they give you an extra attachment point for your stuff.
