rab
- Aug 16, 2009
- 3
- merkur
1983 ranger that had manual brakes that i swapped to power brakes.
So heres how i did the swap...
87 power pedal cage
90 brake booster
90 master cylinder
95-up dual piston front calipers
stock 83 ranger rear drums
stock 83 proportioning valve
Also when i did this swap i had to use some brake line adapters at the m/c to adapt to the stock 83 brake line fittings.
So whats happening is i can not bleed this brakes, fluid is flowing back into the master cylinder when i pump the pedal, that must be causing it to keep adding air to the system.
I bought a brand new master cylinder when did the swap and yesterday rebuild the used one i had, both of them are doing the same thing, i.e. fluid is rushing back into the m/c...
i bench bleed both m/c's before installing and spend hrs trying to bleed the brakes after installing each of the m/c's, also when i bleed them on the bench there is no back flow. also each bleeder screw has plenty of pressure so nothing is really backed up.
So I'm running out of ideas on what else could cause the fluid to back flow back into the m/c.
maybe the proportioning valve needs to be swapped?, any ideas or input would be greatly appreciated.?.?
87 power pedal cage
90 brake booster
90 master cylinder
