Bronco II Cowl Cover?
The Slider
Castroville, Texas
1972
Does anyone make a cowl cover for the Bronco II / Ranger to keep out the leaves?
Thanks!
Chaz
JerryC
56
Tennessee
2.9
I've thought about using magnetic Heat/AC vent covers, Lowes sells them 3 for ~6 bucks.
I ended up cleaning the garage and parking it in there.
17,804
SW Iowa
If you want to get wild the second gen have small holes rather than slots in the cowl...
Sean's84
8
BonnyDoon, CA
2.8l
When I had it parked under a couple of tan oaks, I ended up making some cowl covers using hardware cloth and some scrap sheetmetal. I had problems with oak leaves getting in and holding moisture against the inner cowl which is pretty typical. The mesh worked great to stop the big flat oak leaves.
Now I have the same issue with redwood duff, and when dry the stuff crumbles into tiny kernels, so the mod hasn't helped that as much. I put a tarp over the cab and cowl now since it works to keep both the duff out of the cowl and it stops the irritating leaks when it rains.
I also put mesh over the side vents behind the fenders since I was sick of having rats stuff the blower fan full of acorns. At least that worked to keep the rodents out (haven't had the acorn issue in almost 2 years, and for a while before I put screen over the vents, I was having to clean it out every month or so). So, small victories.
bronco2fan
10
Copperas Cove, TX.
2.8 V6
2.8
3 inch body lift
