Build me a computer
6.2
11
Rural Manitoba, Canada
Hey folks. Looking to get a new computer. Decided to buy parts and build rather than buying pre built. Save money, and have better performance.
However I have no idea where to start. What works with what, and what the good parts are.
So I turn to you.
Budget. $700 +/- $50
Main use will be video editing, little bit of gaming, and daily tasks.
I edit HD video, and my current laptop does alright, bit it leaves a bit to be desired mainly in terms of processing the final video, and keeping the "preview" while editing smooth. Right now it lags a bit. I'm guessing that's meaning I need more memory?
Anyways, video editing PC, for around $700
I'll hook it up to a 27" monitor.
killj0y
11
Edinburg, TX
2.3l 4 Banger
Fix it till its broke!
So I turn to you.
Well in my opinion a good starting point would be the processor. Deciding on Intel or AND and what socket will determine your motherboard and RAM choices.
Your budget is decent but you'll have to forego some of the gaming prowess.
Video card will be on the budget side as otherwise it could easily take up the majority of your budget.
RAM you can get away with 8 gigs of whatever type that should be enough for what you'd like since I think that's the sweet spot.
hard drives I would stay away from any "green" drives for what you want, get a standard 3 Tb for storage and maybe a small SSD to boot from 120 to 250 Gb. Try to include a drive internal or external to backup too.
power supply get at least 600 watt if not more, I prefer modular because you can keep cables you don't need out if your way. Get a quality PSU! don't cheap out here. you also don't need a huge top of line unless your gonna be running 2 or more video cards.
case and motherboard form factor depends on your needs and it's final location. I prefer a case on the larger side so I can work comfortably but smaller is ok so long as you can get cooling to the right places. I prefer those with larger 200mm fans so it can be cooled quietly especially the hard drives. motherboard get something with solid state capacitors and enough sata ports for what you want 6+ of them. because you will be using optical media and at least 2 drives and maybe more down the road, since video can eat room like no business. so 2 disc drives and 2 hard drives plus maybe an external connection is already 5 sata ports you dig?
I think that covers most of the harder stuff just don't forget a keyboard and mouse, sata cables, etc...
6.2
11
I don't mind skimping on the more gaming aspect of things to get better video editing, or cheaper. I'll not a huge gamer, just like to play the odd game.
I did a bit of research last night at work, I'm thinking an AMD 6 core, or 8 core would be a gold idea, then go note budget sided on the video card to even out the $$ figures.
Mark_88
240
Ontario, Canada
Dordge
3.3 Fuel Injected
Love Thy Neighbor
Personally...I'd buy a used system from a computer store or even a hock shop...and build that up...you know it works...you can see the specs and tell if it's going to do what you want...and it is dirt cheap to start with.
I've seen used brand name computers for as little as $200 that would suffice your needs initially...and are upgradeable also...to the kicka$$ point and beyond.
Well, actually, my current computer was found in the trash...it's getting old now and could probably be replaced for cheap for what I do...but it works...
