cam synchronizer alignment w/ pics
downer
4
97 4.0 OHV 4x4
i think i may be overthinking this. So i have no cam sychronizer reference for this engine, i'm working through a full rebuild of the original 97 block. It's so much easier to deal with this when the engine is out of the truck. can anyone verify which way is correct? i believe the second set of pics are correct, with about a 60 degree angle from longitudinal centerline. #1 cylinder is at 10 degrees after TDC.
#1
27316
OR
#2
27317
27318
avid
26
Omaha, NE
XLT 4.0 OHV 4wd
The second set of pictures should be correct: it should be angled toward the rear passenger side. I just did this last fall on my 98 4.0.
avid
26
Omaha, NE
XLT 4.0 OHV 4wd
This is viewing it from the rear with the cap tool on. I originally placed it while I had the engine out but then had an engine code (pointing to the cam sync) come up once the engine was in and running. So I stripped it back down to the lower intake to get access to it. I had to stab it in there several times to get where I felt it was as close to the angle as prescribed. The other thing I did was turned the sensor roughly to the same angle (rather than pointing it straight back). Since this it's giving me no codes. Have driven it approximately 3500 miles.
Also, there was something with the caps. I think the Autozone rentals said the yellow cap was for Fords, but if I recall correctly it was the Gray cap that actually fit the apparatus and did what it was supposed to do. You might double check this while you have the engine out.
Blueovalsam
Kannapolis nc
Thanks for posting I have 92 4.0 ohv with 347,000 it’s tired I bought a complete running 94 explorer with a 4.0 ohv. The explorer motor has the cam sensor but my 92 does not?? Will the 94 motor work in my 92??? Cpldad1972@gmail.com
Semper fi
Sam
snoranger
Professional money waster
ASE Certified Tech
13,653
Jackson, NJ
'79,'94,'02,'23
All Fords
2.3 EcoBoost
Semper fi
Sam
Yes. The 92 should have an oil pump drive plug in that hole. You can swap that into the 94 block, or just leave the cam synchronizer in and not hook it up. Your choice.
Blueovalsam
Kannapolis nc
Your a life saver does that mean that the injectors get the timing and when to fire from the crank sensor
Blueovalsam
Kannapolis nc
Do I need any wiring from the donor explorer or right of do you know if my ranger factory wiring will work Plug in play???
Thanks so much
snoranger
ASE Certified Tech
13,653
Jackson, NJ
'79,'94,'02,'23
All Fords
2.3 EcoBoost
Yes, it's batch fire. It will fire one bank of injectors on one revolution and the other bank on the next one.
Blueovalsam
Kannapolis nc
Hey I dropped in the 94 4.0 explorer motor in the 92 ranger and it fired up that’s for the help
Semper fi
Sam
No members online now.
