CB Antennea
85_Ranger4x4
17,827
SW Iowa
Back when I got it years ago my K40 was supposed to be pretty good. I guess I have whapped it on enough stuff the tip is coming apart, anything better out there now around 4' in length?
Dirtman
13,326
41N 75W
It's up there.
It's down there.
Round.
I poop in the furnace.
The Wilson 1000 is 5 foot and for me gets the best range of anything short of a full 102" whip.
4x4junkie
583
So. Calif (SFV)
Bronco II
2.9L V6
35x12.50R15
×2, the Wilson 1000 is a good equivalent, with a bit better power handling capability than the K40 (has a lower loss coil). However it seems to have become exceedingly expensive over the years, and IMO is no longer a good value.
5' is about the minimum length you need on a 27MHz CB antenna to not have your output performance drop into the crapper.
My personal recommendation for a shorter-than-102-inch CB antenna is the Francis Hot-Rod CB-26 antenna. It's a 66" tall fiberglass antenna with a standard 3/8-24 threaded mount (so will require a separate magnetic-mount purchase if that's what you want). It's output is actually very slightly better than the Wilson in range tests I did many many years ago, but it still fell a little short of a 102" whip (no pun intended).
Bill
898
Sacramento, CA
I think the helically-wound 4 and 5 foot antennas work better than the antennas with coils on the bottom. Both have loading coil losses, but the helically-wound antenna can be an electrical quarter wavelength while being physically shorter than a quarter wavelength, or so I've read. There is still some loss of efficiency from being shorter than the physical quarter wavelength, but you aren't going to notice that much of a difference day to day. The antennas with loading coils on the bottom have losses within the coil in addition to being physically short.
I think the antenna I was using was K40 helically-wound antenna similar to the Francis mentioned. It worked very well for me. I still have it buried in the Garage somewhere.
