Clogged intake ports
pctghost
EMT / Paramedic
5
southport, nc
2.8 V6
2.8L V6
I was pulling my intake and my head's to replace the head gaskets due to leaking. When I pulled the intake there were two middle cooling ports that were clogged with carbon buildup. Is this a normal finding or does this mean there is an issue else where? What can I use to remove the carbon deposits?
Dirtman
13,326
41N 75W
It's up there.
It's down there.
Round.
I poop in the furnace.
I'd be more concerned about how carbon got into the cooling system...
AndyB.
142
Cincinnati, OH
Those aren’t cooling ports, it’s where the exhaust gets routed from the heads to the EGR spacer. You can break up the carbon with a hammer and punch, then shop vac it out.
enginepaul
12
Northern California
2.8
A piece of wire rope chucked into a drill will whip around and break it free. Soaking in water will soften it, but that shouldn't be necessary. It does not have to be perfectly clean.
pctghost
EMT / Paramedic
5
southport, nc
2.8 V6
2.8L V6
Thanks, I ended up use a hammer and punch to break it up and then a pick to remove the little pieces.
  • ryan
    Forum Administrator
