Coolant problem!
Funnycarguy
Nc
Hey guys
My first post here but im really stumped on this one my coolant in my radiator, the thermostat housing, and well im assuming every where else is a orange color but has the consistency of cool whip thats the best way i can describe it. I have pictures on my phone but it says they are too large to download. Iv flushed the motor and heater core out and putting a new radiator in and gonna see what happens. Any thoughts?
Thanks!!
alwaysFlOoReD
5,092
Calgary, Canada
'91, '80, '06
Ford, GMC,Dodge
4.0,4.0,5.7
I've heard that mixing certain coolant of different colors can cause a jello like consistency. Use water to fill and change it several times before putting in the permanent coolant.
Funnycarguy
Nc
Thanks! I was kinda thinking the same i dont see any signs of oil or transmission fluid in it nor do i see any coolant in them either and it runs pretty good for it to have a possible head gasket issue. But ill definitely do that before i waste all that coolant
8,370
Yes, +1 ^^^
There are 3 "types" of coolant, and just a heads up, there is no "standard" for coolant color, so you have to READ the label
The original Silicate based, usually Green in color, lasted 2 years before it needed to be replaced
OAT(organic acid technology) lasts 5 years, usually red or pink in color
These two CAN NOT, under any circumstances, be mixed or you will get a sludge
HOAT, is the newest, hybrid organic acid technology, its usually gold or yellow, it is often advertised as "lifetime" which means 5 years, that's a new car's "lifetime" according to auto makers, lol
HOAT can be mixed with silicate or OAT without issues
So if you are not sure what you have in the system then replace with HOAT and run that to be on the safe side, it is of course the more expensive type :)
You also may have a blown head gasket or cracked head
What engine do you have in your 1999 Ranger?
Funnycarguy
Nc
Yes, +1 ^^^
Thanks for the info!! Its 3.0 with an automatic.
It could be that but im not seeing any other signs of it but time will tell after i drive it a little and see what it looks like
Josh B
1,986
Oklahoma
Sounded like oil to me also but what RonD said also makes sense
maybe try putting some in a plastic cup overnight and see if it separates
Funnycarguy
Nc
If oil is the culprit would there be coolant in the oil as well?
8,370
Oil is not a bad guess either, how did it get in there? people don't always "know" what they know
Especially if you know the 710 joke....................................
Wife calls and asks "what's the 710 cap for?"
Got me never heard of a 710 cap.......................................
OIL cap is on upside down......OIL/710
eye of the beholder, lol
But in fairness when you turn the OIL bottle upside down to pour it in............you are adding 710 to the 710 hole :)
3.0l wasn't known for cracked heads or blown head gaskets, 4.0l OHV was
Funnycarguy
Nc
Haha this is true i havent had it too long so its hard to tell whats been through it but im gonna hope for the best and hope it was maybe some mix matched coolant not getting a long and run with just water for a little while and see what it looks like
Josh B
1,986
Oklahoma
I've seen it in an awful lot of others too, through the years, Mr Ron , although I'd never wish to question your expertise :)
Josh B
1,986
Oklahoma
It would most likely show in the oil side sir
