Correct starter drive?
1984ranger28
5
Davison, Michigan
2.8l
Hi, the starter drive on my starter has broken a tooth off. If you've read my other post, Rockauto does not have the correct sized drive. I really need to get a correct sized drive gear quickly. Thanks, Lucas.
1984ranger28
5
Davison, Michigan
2.8l
Finally found a gear that would work. Its a 11 tooth instead of the factory 9 tooth gear. Starts with no grinding at all. Incase anyone else has this problem the part is a Standard Motor Products SDN191.
alwaysFlOoReD
5,029
Calgary, Canada
'91, '80, '06
Ford, GMC,Dodge
4.0,4.0,5.7
Thanks for posting your fix.
Kirby N.
March Truck of The Month
