Crazy Question: Can a bad front wheel hub/bearing cause shifting probs ('08 4x4)
cmattina
6
Now, obviously, common sense says "absolutely not". But, i swear there is some sort of connection.
I had a REALLY bad passenger side bearing. Truck would hardly move (thought e brake was stuck on). I think i didn't notice it quickly because the roads are so rough where I live. Anyway, when i took the hub off i could barely turn the bearing by hand and could see molten steel in it.
Anyway, at the same time the bearing got really bad I found it extremely hard to get the truck into gear from a stop (all gears). After i changed out the hub, the problem seems to have gone away.
My only theory is that a tiny amount of movement in the driveline is required to get into gear smoothly and since my bearing was so bad the one front axle was stopping all movement?????
Perhaps my CV axle is fucked too, and if so, would that cause the shifting issue?
Uncle Gump
Token Old Guy
13,436
Ottawa IL
Ranger/BroncoII
4.0L SOHC/2.9L
Preloading the driveline with a stuck axle will cause the condition...
Denisefwd93
74
South East PA
Try going to neutral second and then into first I find that usually helps a lot more than going right into first
cmattina
6
Yeah, i find that to be necessary since i got the truck at 60 000km (and every other Ranger i've had). Not being smart - just agreeing with you
cmattina
6
Okay,
So you are saying my axle could have been stuck, which makes sense to me considering the state of the bearing. How was i pre loading the drive line?
Is preloading the driveline taking all the slack out?
Denisefwd93
74
South East PA
Maybe also time to check, scrutinize all the lubrication fluids down under
Uncle Gump
Token Old Guy
13,436
Ottawa IL
Ranger/BroncoII
4.0L SOHC/2.9L
By rolling to a stop and having the wheel stick...
cmattina
6
Good point. Tranny fluid has about 35000 km and front diff is original at 95 000 km...
