Dana 35 l/s
martin
26
St Bruno, Quebec
1991
There are two varieties of rear 35. c-clip and non c-clip. I have aquired a c-clip axle with a good l/s but the gears ore toast. Will this carrier work in a non c-clip axle? The story is., my son has a jeep (yea I know, no comments are necessary, even though it is impressive off road) and the rear axle is a leaf sprung non c-clip axle and I would like to put the l/s in for him but the axle with the l/s is a coil sprung c-clip variety. I know I could cut off the brackets and convert it to leaf spring but I would still have to re-build it and install new gears. I'm really looking for the quickest route as I'm leaving in ten days for a couple of months and would like to get it in for him before I leave.
metalmacguyver
Yeah, I built that.
11
4.0, 7.3
it might if the bearings match as does the spline count. this is a better question to ask on a jeep forum. the best i can say is try it and see if it fits. dont forget, you will need to set up the gears again.
martin
26
St Bruno, Quebec
1991
Thanks for the reply. I thought someone on here might know. I seem to recall someone asking if they could use a d35 l/s carrier in the front end on a ttb. If it can be used in a ttb then which carrier fits the ttb or do neither on them fit. I do have an axle of each variety here but I don't have the time to pull them apart and play mix and match at the moment. If I don't find a difinative answer before I leave he'll have to wait till spring time. Gears are no problem, I have a big hammer.
