Dana 44 ttb
Chris_97
I have a chance to get 95 f150 running gear for next to nothing. I don't want to cut the axles down like it says in the tech library so any advice on how to mount them full width? thanks
4x4junkie
583
So. Calif (SFV)
2.9L V6
35x12.50R15
Lengthen each beam 1 inch next to the pivots, and the axle should fit right into your existing axle pivot brackets. You'll need to do a bit of fab work for matching up your coil buckets and radius arm mounts, but this isn't difficult to do.
I believe the stock D44 steering linkage will bolt up too, though don't hold me to that. You'll probably want to re-ream the taper so the steering mounts on top of the knuckles though (gives a little better steering linkage angle).
